This question pertains to RV use. I have installed the Multiplus 12/3000/120-50 into my RV. I replaced the OEM inverter and rewired so the Multiplus powers the main distribution panel.
My question: The AC2 operates only on shore power. I want to run the AC2 to a sub panel and then run a few plugs to items I only want to run off shore power. Have any of you installed a AC only sub panel in your RV. What Sub panel have you used. I don't want to put a second panel in with DC power combined. This is will be an only AC panel.
