glowworm238
- Feb 22, 2020
- 6
Here are some of the build photo's from my first trailer build. It is a 2020 Runaway 6'X8' Venturist. I bought it last March and due to the current events had plenty of time to build it. Its comes as an empty shell with 1 Shelf and a small window A/C that uses ~ 365W max. I built the interior out of 15 series 80/20 aluminum extrusion and bamboo. I converted the original power system comprising of a 15A shore power plug, a metal wiring box, and 2 power strips to a 24V system that uses 4 UT 1300 batteries, Victron Multiplus Compact 24V/2000/50, SmartSolar MPPT 100/30, 3X HIGHTEC Solar 200W+25% panels wired in series. Its been a fun build and this forum has been a big help in designing my system. It's been fun trying to figure out how to fit everything into such a small area, but everything fit.
Picking up the trailer
Removing front shelf and factory wiring.
Initial assembly of the interior
Test fitting battery location. I chose this location due to it being directly over the axle and it would help offset the weight of the propane cylinder and a passenger side awning.
Frame assembled with the T-Fuse and 1/8 rubber for some vibration reduction
Fitting the Smart Shunt and Main battery disconnect. Batteries are wired in a 2S2P configuration with a T-Fuse before the Main battery disconnect.
Initial test fitting of the SCC and Inverter
Rear of the front 120V plug and 3 port 24V power plug
Front 120V plug and 3 port 24V power plug. The factory 15A shore power inlet is run thru the floor under the camper to a 15A circuit breaker in the rear before going to the Inverter. Due to this15A plug, I limited input of the inverter to 14A and turned off the inverters capability to subsidize the shore power.
