danielfp248
Battery researcher
- Sep 7, 2020
- 431
Glad you like itI already emailed them regarding sample, so lets see how that turns out and ofc I will make sure you get some. I am going to look over the book I linked to just to see what I can pick up in terms of info.
Maybe there is a way to make the ceramic silicon with nicer chemicals...
There is a very good reason why these chemicals are used. Common soluble silicon precursors, like potassium silicate, will lead to charge neutral silica gel, which will not have any cation or anion selectivity. This is why TEOS and MPTES are critical to the setup.
I have potassium silicate solution and several mineral acids, plus fiberglass membranes. To do a simple test I prepared a silica gel fiberglass embedded membrane by dipping it in potassium silicate and then in 10% phosphoric acid, then drying it at 50C. I repeated the coating process 3 times to ensure the fiberglass was completely saturated with silica gel. I then measured the permselectivity of this membrane, which was <5%, as expected. To introduce the charged groups that give a membrane anion or cation specificity, you absolutely need more reactive silicon species that are adequately functionalized.
So they definitely make it look much more trivial than it is. You need the proper precursors - that provide the proper functionality - and then careful proportions to get the proper nanostructure. This is what the patents do show.
If you get some do send some my way, definitely a very interesting approach to test if you can get your hands on a membrane.
