danielfp248
Battery researcher
- Sep 7, 2020
- 431
I am now doing a test with new cell with ZnCl2 15m + KI 2.5m in distilled water, MGL280 cathode, Zn anode, W42 separator. I will charge to 1.3V, discharged to 0.5V at 5mA. This will allow us to see the effect of lower KI.
I have put the graphite electrodes of the Swagelok cell in ethyl alcohol to clean them. The alcohol immediately turned very yellow, a sign that the graphite has absorbed a lot of iodine through all the experiments. I have therefore decided to move to my Titanium electrodes, as the graphite seems to interact a lot with the iodine which has probably contributed to cell instability over time (as the electrode mass is much larger that the battery's cathode/anode and it is probably "soaking up" iodine from each device).
I will now do a test with the most successful electrolyte up until now (15m ZnCl2 + 5m KI + 5m NaCl in white vinegar (4% v/v Acetic acid)) a zinc anode, W42 separator and a Spectracarb 2050A-1050 cathode, using the Ti electrodes in the Swagelok cell. I will post the results as they are obtained ?
- I don't think white vinegar is a good idea. It has a complex composition and contains protic acid which may offer activity H+.
Reasonable,my fault.Bear in mind that the pH of a 15m ZnCl2 solution is really low (pH < 2), given the pKa of acetic acid is 4.75, it provides no protons under these conditions. Given that ZnCl2 is several orders of magnitude more acidic (very strong Lewis acid), the acidity of acetic acid is not relevant. It does seem to improve ion mobility though.
After doing a lot of reading on water-in-salt electrolytes and Zinc dendrites, it seems clear that Zinc deposits in these electrolytes are only dendrite free under low current densities. In all the published studies using WiS electrolytes, the maximum current density used is usually around 1mA/cm2. Below this density the deposits are compact and highly reversible while above this current they start to have significant dendrite formation.
Additionally, trying to use the fiberglass separator has been complicated due to its very high porosity, I get shorts right from the start in around 1 out of 3 assembled devices, for this reason I am going to continue with the Whatman 42 paper, while I look for other separator options.
Right now, I am testing a device using a 15m ZnCl2 + 5m KI + 5m NaCl in white vinegar (4% v/v Acetic acid)) electrolyte, a zinc anode, W42 separator and a Spectracarb 2050A-1050 cathode, using the Ti electrodes in the Swagelok cell. However, I am charging to 1.6V at 0.5mA (0.38mA/cm2). It will take a long time to get some long term results, but there should be a big increase in capacity. I will post the first cycle information later today.
Total thickness of this device is 0.0454cm with an area of 1.29cm2, volume is 0.0586cm3.
So I decided to not run this experiment, as getting long term cycling results of batteries at low current densities is not practical, it would take months to get hundreds of cycles. The lowest current that I believe is practical to gather results for me is around 2.0mA/cm2. This means I will need to start testing solutions to alleviate the dendrite problem in the WiS electrolyte. Here are some of the additives that have been used in the literature to reduce dendrites with some success (some which I tried with the Zn-Br cells with some success):
I have cetrimonium chloride, which has been tested to reduce dendrites in lithium but not zinc batteries, so I will try this one first. I also have Tween-20, which I used in Zn-Br batteries successfully, so that will be my next try.
- Boric Acid
- Thiourea
- Cetrimonium bromide
- Sodium dodecyl sulfate
- PEG-200
- Tween-20
The first attempt will be a cell with a 15m ZnCl2 + 5m KI + 0.00375m cetrimonium chloride (around 1200ppm) in distilled water. The cell uses a zinc anode, W42 separator and a Spectracarb 2050A-1050 cathode, using the Ti electrodes in the Swagelok cell. Experiment will be to charge to 1.3V at 2.5mA, discharge to 0.5V.
Daniel, thank you for sharing your experience and I keep my fingers crossed for finding the optimal solution. Are you thinking about other types of cells?
So both cetrimonium chloride and Tween-20 gave similar results when using graphite electrodes, both had shorts after only a few cycles. Interestingly the cetrimonium chloride at 300ppm enhanced the capacity of the device significantly (allowing me to go near 40 Wh/L at 2.5mA) but dendrites formed a lot faster than with the standard WiS electrolyte. I was only able to complete one cycle before dendrites shorted the battery.
I found a really interesting method to modify Zn anodes (https://www.mdpi.com/2079-4991/11/3/764) which involves depositing a thin film of Cu over sanded Zn anodes using a 0.1M solution copper sulfate. Since I have copper sulfate I tried this out, a black copper film was deposited by placing 100uL over freshly sanded zinc anode disks with a 0.5 inch diameter, left for 3 minutes, then washed with distilled water and dried in the air. I prepared 4 anodes in this way.
I am now cycling a cell with one of these anodes, a 15m ZnCl2 + 5m KI in distilled water electrolyte with a W42 separator and a Spectracarb 2050A-1050 cathode. I am charging to 1.3V and discharging to 0.5V at 2.5mA.
Email one of the researchers to get their thoughts and take a stroll in a nearby park to get your mind off things for a bit?...It is however quite mysterious,... no one in the literature seems to be having problems...unsure which way to go.
Wish I had more to offer.
Possibly you're too focused on dendrites and its something else or something really crazy (e.g., dendrites dissolve when no current is flowing but have an ion-path so they can reform instantly when current is applied).
