Hi all,
I am building a sort of solar sailboat. It's a small houseboat that will be all electric, including the outboard motor.
I'm hoping to first have someone review my 'Back-Of-The-Envelope Calculations' here in terms of batteries required with a given set of solar panels.
From there I'm hoping to get some advise on individual components etc.. But I thought I'd better make sure my high level understanding is correct prior to diving into the details.
I'm an old moron so please be kind if I've seriously miscalculated something!
Power requirements:
A powered cooler - Similar to a Dometic CFX3 45 - ~4300 Watt hours per day
Air Conditioning - Probably a Zero Breeze but there are other options. I figured 12 hours a day of run time to be safe but I think it will be far less than this with open doors and windows a bit off-shore with no bugs and a fan - ~1800 watt hours per day.
Misc stuff. This includes a tablet, led lights at night, a chart plotter while underway... 1200 watt hours per day.
A desalination device like the 12V Rainman Watermaker System. This is for toilet flushing, quick shower, and drinking water etc for 2 people.
- 1536 watts hours per day to make about 32 gallons of fresh water.
The motor - I'm planning for 2 hours of runtime per day. If emergency runtime is needed beyond that I am planning to have a portable gasoline powered generator on board and I'll be asking about that later... but for now planning on 2 hours of runtime is more than plenty for the trips I'll be doing off battery / solar. I hope I'm not breaking a rule with this link but this is the motor I'm looking at - https://www.elcomotoryachts.com/product/ep-20-electric-outboard/
17760 watt hours per day
Total - ~26596
I'm in Florida and planning to put 4 200 watt solar panels on the top. I'm planning for that to produce on average -
~5600 watts per day
So my battery capacity per day will need to be about 21,000 Watt hours per day
I was planning on 8 or 12 12V 206Ah LiFePO4 Lithium Iron Phosphate Battery that would be wired at 48Volts.
At a high level do these numbers seem at all close to reality?
Thanks for the help!
Don
Power requirements:
Total - ~26596
~5600 watts per day
Don
