John Frum
Tell me your problems
- Nov 30, 2019
- 15,233
Got the new bms app and decided to fiddle with the administrative enable/disable toggles for charge and discharge.
Baseline: system is totally idle. Inverter is off.
Discharge disable/enable works as expected.
When I open the discharge path my battery monitor turns off.
When I re-enable it the battery monitor shows 26.3 volts same as the android app indicates.
Charge enable/disable gives unexpected results.
When I open the charge path my battery monitor shows 25.8 volts which is a surprise.
Can someone else confirm my results please?
