meetyg
- Jun 4, 2021
- 1,526
Hi there.
I'm working on my setup for 2 x 24v Lifepo4 (100Ah each) in parallel for a 24v 3k AIO Inverter.
I am planning to place this breaker board in a metal enclosure that I already have, so space is somewhat limited.
Basically what I have is two 125A DC breakers (one for each battery) going into busbars, and then busbars going into a larger main DC breaker (160A).
Since the batteries will be placed side by side below this board, this is the setup I've come up with:
As you may notice I also have a small DC breaker with inline resistor for manually pre-charging the inverter capacitors, before turning on the main DC breaker.
I'm not really happy with the criss-cross setup of the wires from the smaller breakers to the busbars. What do you think? Are there any implications? Will this cause any trouble?
Wire guage from each small breaker is 4 AWG Silicone insulated, and to main breaker is 2AWG.
Might be a bit on the small side, but I don't plan on pushing it anyways with the inverter.
I'd love to hear your thoughts.
P.S. ignore the red heat shrink on the black wires. I ran out of black, and will be replacing it when new supply arrives.
