dreancestere
Since we're in the middle of our annual cold-snap down here in north central Texas, I thought I'd stick a chart of my 3-ton Bryant heat pump's daily electricity use over the last 1-1/2 years. In general, it's fine. But, when it gets cold, it really starts to suck down power (especially when it drops below 20 degrees F when the supplemental electric heating circuits start kicking in). You can see the huge spike in power use last year at about this time (when it got down to about 5 degrees F). Last night, since it was in the 20s for most of the night, it drained my 19.2 kWh battery in less than 3 hours.
EDIT: I've updated this chart to include data from the February 2025 cold snap. Also, just for grins, I calculated average and standard deviation for this data. The heat pump averages 21 kWh with a standard deviation of 21 kWh. So, about 68% of the time the heat pump uses between 0 and 42 kWh per day.
