Hi,
I've joined this forum recently, but I'm not new to Renewable Energy projects. I've been building wind turbines for myself for 20 years and it's been a very satisfying project all this time. I'd like to tell my story - I hope you folks will enjoy it.
I'm entirely aware of failed WT products that don't deliver what they promise, and expensive WT project boondoggles in the news. Obviously, when more is promised than can be delivered, disappointment ALWAYS results. I don't want to talk about that stuff. I'm here to claim that I figured out how to build WTs that deliver what's expected.
I had a lot of help along the way. Hugh Piggott's plans were essential to getting me started on the right foot when I built my first WT's. The HAWT designs that he provided in workshop plans and United Nations sponsored development projects are extremely valuable. Any WT that promises more than what a Hugh Piggott WT can deliver is simply false. I also came across the old Fieldlines forum, which, back in the early 2000's, had members like Zubbly, Ghurd, Ed, and Jerry, who were ingenious tinkerers who could make a generator out of anything. With Hugh Piggott blades and Zubbly generators, I had the ingredients for successful wind turbines.
Here's my first HAWT wind turbine, first raised July 7, 2007.
Note that it had 4 blades but I soon changed it to 3. Its tail was too small, eventually being replaced by a tail vane 3x bigger.
You can barely see the generator - that's because it's too small, too. It burned out in less than a month. Examining it, I realized what I'd done wrong, lesson learned. In the meantime, I had been given an old industrial 3-phase motor by a friend. Since I had already started planning to convert it into a generator with Neo magnets, my WT was back up and running only a couple of months later.
You can see details of the motor after being converted, but you have to see inside to understand what I really did to make it into a generator. Note the extra long shaft coming out of the motor - I turned a whole new rotor and shaft using the lathe and milling machines at work. And I made a new hub, too, fitted with just 3 blades. The tail was also improved. At the time, my welding skill was still pretty brutal! I think I did that one all with my acetylene torch.
This WT ran for a year and a half, until an accident handling the tower caused it to fall and be smashed!
Not daunted by this! I had measured performance of this generator and realized that there were still improvements to be made on what I had previously done. The tower was completely recoverable, and so was one of the blades. Given that I had removed the 4th blade before, I only had to make 1 blade and a new generator.
I'll hit the Post button now, and continue on in a subsequent post. Not sure how many pictures can go into one post at a time.
