Hello everybody
As my home face some electricity outages i decided to buy and install my first solar system, as the prices are exaggerated in my country, I ordered an inverter online it was Sako Sunpolo 6kw hybrid I read everything about it and i liked it.
thankfully its arrived to me today, and before purchasing batteries i want to test it so my first question :
1- can i plug the AC in cable to the wall and check if its working and connect it via wifi etc ...? or its not recommended ?
also I'm planning to get 4x200AH 12V gel or acid batteries to run it , and regarding my calculation using (Imax= P*Pf/η/Umin/N/n) and considering a load of 1200VA the Imax = ~24A it should get me up to 8 hours for Shoto 6-FMX-200 :
2- However some engineers told me it will be only 5 hours so which is right? i would need 3 hours max , I won't install solar panels for now and incase of long outages i have a DG.
3- also what wires Gauge should i use? regarding Sunpolo 6KW manual it says 10 AWG for the AC input/ouput , which i feel its low and for batteries it recommend AWG 2 but it doesn't clear if same gauges should be used in the batteries DC-DC connection.
4- Is there any thing wrong in my plan ? and incase i cheap out and got 4x100AH batteries how much time this system will get me?
5- Is it safe to run an 18000 BTU 9 amp (startup current 20amp) A/C on it ? im not planning to run it on it but it will be simpler work for me if included it in the connection , just incase i added more bat or panels in the future. I will only connect it to the lights TV - none heavy outlets and the A/C wont include the kitchen or heaters.
6- I have two options for installation , first I install it beside the main circuit breaker box inside the house which is cooler due to the A/C, second which i like more is to install it outside the house , which is closed area (with roof so no raining of any kind its 4x10 m area with only last 2x2 m without roof so its almost like an indoor) however its hotter in that place, i like this place more as it wont ruin the look of the house also more room for batteries etc. and i will just need like ~3m AC cables to connect the main circuit box to the inverter, is it ok to install it outside?
Thanks in advance
Thanks in advance
