Hi people,
I'm looking at installing a 8.5kW grid tied solar system for my home.
Full disclosure, I'm Canadian. Canada has likely the worst rebate/credit available for residential systems. Likely I'll get $0.20 - $0.30 rebate per watt. So somewhere close to $2000 in rebate.
The panels I'll likely go with are a Canadian Solar 330 watt panel, which I can get for a pretty good price - around $5300 USD for 8.5KW
I'm looking at either the NEP BDM-250 Micro inverter OR the Enphase M250. NEP has better support in my location as a few installers carry their product so support and warranty claims may be better as a result.
From what I understand if I go with the NEP or Enphase micro inverter I'll need one per panel which would work out to approximately $4300 USD. To help with cost I've also been looking at the NEP BDM-600D which is a dual inverter, can put two panels on one inverter and daisy chain the inverters together. I can do 7 devices (14 panels) per 20Amp circuit. One string would have 12 panels and 6 BDM-600's and the other would have 14 panels and 7 BDM-600's. The cost of 13 BDM-600's would be slightly less then the 26 micro inverters at $3850 USD.
So for just panels and inverters, if I go with the BDM-600 my total taxes in would be $9150 USD.
I'm also looking at doing a ground rack system but have no clue where to start with that. Lots of sites but it seems like each piece needs to be ordered individually. I'd like to do screw piles for a foundation. Then run the two AC lines underground to my panel in the house. The run would be about 100 feet.
What foot print could I expect from a 26 panel ground mount array?
My total budget for this build is $13000 USD. I will pull permits obviously, do all the work I can do and have a licensed electrician do what they MUST do for the permit. I'l also need an inspection before the system can be turned on and a new net meter installed on my house by the utility company. I'm expecting $1500 USD for permits, inspections and the electrician doing what they need to do. Then likely $2000 USD for a rack. That gets me close to my $13000 USD budget. This is before cables, housing, electrical panels, and all the other things that add up quickly.
Advice? Tips? Tricks?
The other thing is this is a horrible investment where I live. The net metering program offers credits for the surplus power generated however, say in one month I generate 1kwh and consume 1kwh for a net of 0, I still pay tax on the 1kwh I used even though it was completely offset by the power credited to the grid. Any excess credit come March 1 just go to 0 - which I wont have to worry about since I will never produce more in 1 month then consumed. I'm also worried about how this will affect my property value, unlike most I do not want to see an increase in value as I plan to not sell my home any time soon and I don't want my property taxes to increase. Also, I have a big family, my wife and I plus 3 kids and 2 foster children. We also have a big house (for Canada) the total finished living space is 4500 SQF and including our unfinished basement we are close to 6600sqf. We also have 2 forced air electric furnaces that are 15,000 Watts each and two large heat pumps. It's cold in Canada and when the temps hit -16C the heat pumps shut down and the furnace kicks in. in 2019 we consumed 45,000 KWH which cost $4500 USD, I'm hoping to see this system get $1200USD in annual credit. The ROI is terrible at likely close to 10 years. However I'm optimistic that electric prices will only rise and the offset would be greater at that point. Plus I'm looking at ways to get our monthly expenses as low as possible and while it's likely going to only be around $100 less a month for power it's still $100 less.
I've already done most of what I can do to get our electric bill reduced. I've changed all the lights over to LED. I put motion switches in our kids bedroom, basement and garage so when the lights are left on they will turn off when no one is in the room. Our HVAC is serviced regularly and runs as it should. I've looked at switching out hatter and furnace to natural gas vs the electric system we have but the cost associated with running a line to the house and converting and replacing furnaces and water tanks is far to much - especially when the furnaces and water heater work just fine now. I'm looking at changing our cooktop to propane. Any other tips for reducing consumption?
Thanks in advance.
Thanks in advance.
