TheDoctorUSA
Hey everyone!
I finally reached the point in my build where I turned everything on this morning, and... IT WORKS!!!
I would like to thank @Will Prowse for his video, if it wasn't for him, I would have never realized how easy and accessible solar is...
This is my 39feet trailer, everything was done with lag screws in the roof attached to brackets and unistrut, I got the idea from @mmmmmdonuts and they were so kind to provide me with all the links to buy everything + instructions.
AFTER incentives, I have spent a little over $5,000, which I hope to gain back in 2 years.
Now, I definitely have to clean the cables up, add conduit, add a fork to the ground wire and hide it. But this is what it looks like so far:
- Sungoldpower 10kw
- Yixiang DIY 16kWh
- 2 series of 6 430w bifacial SEG panels (12 panels total 5.1kw)
- 2 DC breakers
- 50 + 20 Amp outlet with a NEMA 14-50 and a GFCI 20amp outlet
I even put some juice in my Tesla!!!
I do have some questions though:
1) Does anyone know how Sungoldpower neutral ground bond works? I tried asking them but they could not give me a straight answer, here's my problem:
When I first wired everything up, I was measuring 120V between L1 and G, which technically means bonded, right? Now here's the issue: not only I wasn't getting any continuity between N and G, but my Tesla charger was throwing a "bad ground" error.
I ended up bridging N and G bars in my outlet panel and it worked... So what does that mean? Did I have a bond at the inverter or not? Definitely don't want to end up with a ground loop.
2) I have a ground rod driven in the soil next to the shed, my set up right now goes underneath the shed (touching the metal sheetings) and then in the ground rod, is this a decent way to include my metal shed in the grounding?
For my usage, I will charge my Tesla a couple times a week, and use the remaining for my trailer!
As for panel production, I am very satisfied as of now, I had a peak of 3.8 kW which is on par with what PVWatts says, so if the predictions are right, I will end up producing almost 8000kWh in a year (which is already $3200 in savings!!!)
You can see the times I shut everything off to make adjustments, but minus that... the production seems great. I also tried to charge my tesla first at 32A and then 16A, the inverter did not bat an eye...
I'm so thankful for everyone in this forum who helped me make this dream real! Thank you guys!
(Another special thanks goes to @BaylentheSky and @1ufvlsi6x for helping me understand grounding)
P.S. I'm adding some closed cell spray foam in my shed very soon, with some ventilation, so should be interesting!
- Sungoldpower 10kw
- Yixiang DIY 16kWh
- 2 DC breakers
