Bossrox
Solar tinkerer
Will they work together? Yeah & here's what my testing revealed.
Seeing the discharge curves are quite different for each type, I theorized that 'cuz the near end of cycle for lith's is about what a fully charge agm bank is & that the lith's would likely take on most of the energy initially & the agm's would start kicking in more & more as the lith's got depleted.
Well, I imagined right. The lith's take the full discharge til it reaches about 25.5v & til it gets there, the agm's didn't squirt out an amp
& this is intresting. If I ran a heavy load that drew the lith's down below 25.5v, the agms would kick in but this is the intresting part. As soon as the load cuts back, the lith's returns what was used back to the agm's.
There's only 1 drawback that I found tho. On charging, they'll both grab a pretty even amount of current til 1 of the banks is near charged then the more hungry bank will soak up the bulk.
So if like me, you have smaller a/hr agm bank than the lith bank, the agm's will be charged before the the lith's & when the agm's are ready to go into float, it won't happen 'cuz the lith's are telling the charger to stay in bulk charge mode all the way til they're done, which I'm not sure if feeding the agm's a full voltage charge way beyond the point when it was ready to go to float will cause them any significant deterioration is what I need to find out more about.
Anyways, If you ever wondered what would happen if I did this? Now you know. Cheers & Merry X-mas!
