Hi everybody,
I have two 215W solar panels in paralel (total of 430W).
In France it is 1:45 pm, it's really sunny not cloudy and I can read on the MT50 that I only have 141,5W ....
Also according to the main screen of the MT50, the battery is fully charged but I only have 13,8V and my BMS app says that I only have 147Ah remaning on my 280Ah LifePo4 battery. I have the feeling that maybe the charge controller is not allowing a highest charge.
Anybody has an idea where the problem is coming from ?
Here are the settings I am using on the mt 50 :
Battery type User
Batt. Ah 280Ah
Temp Comp. Coeff -3mv/degree C/2V
Rated voltage Auto
Over volt dis. 14,6V
Charge limit 14,4V
Over volt rec. 14,5V
Equal. Charge 14,1V
Boost charge 14,1V
Float charge 13,6 V
Boost rec. 13,3 V
Low volt rect. 12,8V
Under volt rect. 12,8V
Under volt warning 12V
Low volt disc 11,5V
Discharge limit 11,4V
Equalize time 0min
Boost time 15min
Battery type User
Batt. Ah 280Ah
Rated voltage Auto
Charge limit 14,4V
Equal. Charge 14,1V
Boost charge 14,1V
Float charge 13,6 V
Boost rec. 13,3 V
Low volt disc 11,5V
Equalize time 0min
Boost time 15min
