99% sure the indication is used to show the BMS is in protection mode, thus when it displays 'protection none' it suggests that protection has not been activated. This is a little worrying has cell volts has exceeded 3.65, the usual setting. I would have expected the charge switch in the off position and protection active.Do you know how Missoo can turn the protection settings on?
Thanks Mike, I wasn’t sure if there was a manual switching to provide protection or to disconnect it but then again whether it is automatic as you suggest. I agree that the cell voltages are a worry and that is why until the protection is sorted out that Missoo keeps the the battery and cells charged only to the levels i stated.99% sure the indication is used to show the BMS is in protection mode, thus when it displays 'protection none' it suggests that protection has not been activated. This is a little worrying has cell volts has exceeded 3.65, the usual setting. I would have expected the charge switch in the off position and protection active.
Either the cell overvolt value has been changed, the unit has been configured for lithium ion, or the BMS is faulty.
Anyhow I will be leaving all this behind, over to France on Sunday and driving back to south Portugal.
Mike
Just found a screen shot that shows ‘protection locking’ but also indicates a current being drawn.99% sure the indication is used to show the BMS is in protection mode, thus when it displays 'protection none' it suggests that protection has not been activated. This is a little worrying has cell volts has exceeded 3.65, the usual setting. I would have expected the charge switch in the off position and protection active.
Mike
Yes the MT50 is set to user. But what do you mean for the epever?Both the epever and the mt50 are both set to user or lithium...yes?
?Hello to both of you,
I finally went back home.
I charged my battery, then I disassembled it to top balanced it again. Once it was top balanced to 3,65 V, I directly assembled it into a 12V
pack (I didn't put it back in my RV yet).
Should I left it several hours in parallel before assembling it in series ?
Here is what I get on the BMS app. Is the voltage differential of 0,023 V anormal ? You can notice that I don't get "Protection none" anymore but protection cell overvoltage.
Also, I measured 14,65V between the main battery positive and "B-" of the BMS.
But I get 14,35 V between the main positive and the "B+" of the BMS.
Is this normal ?
I am so confused with all of it and I really don't know what to do.
Edit :
Look what happened now to cell number 2. I am wondering if this cell died and if I should replace it...
It's just because the voltage of this cell is dropping?
Why do you think cell 2 has died?
They will all drop to a resting voltage around 3.35.It's just because the voltage of this cell is dropping
Oops 3.38.Edit: how can the cells settle to 3,8v if the charger is off ?
Also the battery pack is not back in m'y RV yet so it doesn't change anything on the balancing cells.
Use select button on epever charge controller...toggle to batt or battery...the first one of 3...it should be the voltage reading....press and hold enter until it flashes...Yes the MT50 is set to user. But what do you mean for the epever?
