DANISH RAZA
- Jun 23, 2020
- 4
Dear all,
I hope everybody is safe and sound in this Pandemic and i pray for the fast recovery of patients.
I am using a Solar Inverter, It is based on MPPT VFD system, Made by Chinese, Its a Battery Less System with a Solar Input of around 6000 Watts DC, to an out put of 220VAC at around 5000 Watts, the inverter unit works fine, but i am having an issue , it shuts down (showing Short circuit ) whenever:
1- i plug in my Power Adapter ie any 12vdc adapter or say a laptop adapter, the unit shows Short Circuit ans shuts down, sometimes it automatically restarts, but sometimes it just haults to a short circuit screen.
2- Whenever i shift from Solar power to Utility power, its shows same symptoms as above, I shift it from an automatic MCC, Magnetic contactor setup ( Solar magnetic contactor switches on and utility contactor switches off and vice versa) or using manual Changeover switch, it shows the same screen and freezes.
3- I have noticed that the small spark that you see whenever plugging in any AC to DC device causes it to Go to short circuit mood.
The Solar System has one 5KVA Inverter ( MPPT VFD Min Solar Voltage 200VDC, MAX Solar Voltage 400VDC, out put 220VAC,
20 x 150 Watts Solar Panels, The output on a Sunny day is around 2.2K Watts, (Photos Attached for reference, also internal components are similar as in photo)
I need your suggestions about, How to avoid these frequent restarts, and inconvenience of your Solar Inverter getting shutdown on a mare 12VDC adapter.
Kindly help me, and suggestions/ideas to improve the situation. My email address is sdaniraza@gmail.com
My name is Syed Danish Raza, I am from Islamabad Pakistan, and an Architect by profession, thanking in anticipation, and once again i pray that everybody is safe and things may get to normal ASAP.
