ricklndn
- Nov 12, 2021
- 5
I'm kinda new to all this, all the information I learned was reading stuff over the internet.
I have 4 12v lifepo4 @ 100ah wired in parallel for 400ah.
My charge controller is a victron 100v 50amp
My charger is victron 25amp
My solar panels are 1400 watts wired in parallel.
I just want to explain first why I have a victron charger, I use this charger to top off my batteries from 7pm till 7am every day.. in ontario this time is the cheapest time to top them up. Having a full charge to start off the early morning works well for me. My hydro bill says I'm using about 0.36 cents a day.. so I must be doing something right, compared to 1.50 a day before this hook up.
I have showed my system in the pictures, just a heads up, that fuse panel behind my batteries is the house fuse panel, and has nothing to do with my solar setup.
I'm sure my setup could use some improvements and I'm open to any thoughts from the members here.
My original question for this post is my settings for both my charge controller, and the victron 25 amp charger, I added some screen shots of my settings, the settings are all default.
Are the default settings the best for my batteries? I want to make sure I get a long life out of the batteries.
