hello all newbe with some questions on MY battery test of new CHINs 200 amh battery set-up for RV. First this is 1/2 of system the RV is at camp and has new 4-100 watt rich solar panels driving a victron 100/30 mppt charger and is working fine on our old led acid batterys ,
this post in about the new CHINS 200 lithium battery and gyanndyl 2200 pure syn inverter and victron 1p-22 charger testing
if we the did capacity test correctly we got 200 amph when batt got to 10.4 volts / but we had to reduce load when the inverter started sounding low volt alarm , the load we started with was 180 amps reduceing to 100amps due to some heat build up at terminals (shut side) and sucked the last 4 amps out with a 100watt light bulb after the first warning . the bms shut down one TIME at 148 amps used (150 minutes @ 170amp load) I think due to over heat caused by the terminals and heat saturating cabels on inside back down to bms though batt case was not hot, cant confirm this but it did shut down and voltage was still above 12 v shunt side terminal was showing 120*f + last check.
SO my questions, 1. the BMS never shut down for low voltage and it got down near 10. 1 volts and as soon as we shut down inverter the voltage jumped back up to 10.60 volts @no load , why is this and is it important and what voltage does BMS use for under volt shut down as CHINS propaganda is vauge ?
2. the heat generated at terminals mostly the shunt side (BLACK). iS the 500 amp rated shunt causing this ?
3. IS HEAT kind of a normal by-product of these things as my charger (30a victron) my inverter (2200w geandyl ) and the terminals / shunt get Pretty warm if not down right HOT roughly all @ 120*f or slightly above ?
the battery really would never be put under the load that it was tested @,
maybe a microwave @ 1000watts for 2-5 minutes the most, see the picts and please advise note planned the inverter mounted piggieback on battery case to afford the short #2 cables at least thats the plan, Jerr
