I have yet to see a solar farm with panels installed vertically. Tells me right away it probably sucks.It's not, it's monofacial. That's why I did it this way. I wanted to see best N-type cells faced in one direction only. My bifacials have horrible gain. I don't have a single panel that could be used properly for this application. I still don't know why people like vertical mount.
ExactlyI have yet to see a solar farm with panels installed vertically. Tells me right away it probably sucks.
I just absolutely love, low tilt, cheap ballast ground mounts.
I love your experiments on the bifacials. The data has helped me decide against them.It's not, it's monofacial. That's why I did it this way. I wanted to see best N-type cells faced in one direction only. My bifacials have horrible gain. I don't have a single panel that could be used properly for this application. I still don't know why people like vertical mount.
They usually have a better warranty as well. The transparent back sheet seems to fair well over time versus the white traditional back sheet.I bought bifacials because they were cheap; winter time will be interesting if it snows, but mainly I bought them because they were cheaper than some of the mono panels of similar specs.
Yet still ideal for playing/testing. Flat or lining a dish for more concentration.Reflectix will also break down in uv.
Maybe to impress your neighbors with your solar powered fence?
Finally some studies coming out on this. I have it searched for any but this video covers some good ones. There's literally no benefit to these things.
When PV panels are cheaper than regular fencing materials (literally the case in my area around January), it's beneficial to mount them vertically.There's literally no benefit to these things.
a Vertical Rotating Pole mountI would say an Antarctica or artic circle system with no obstructions would be great for vertical mount.
Wouldnt you have to spin it twice as fast so youThe frequency of blue-green light is about 700 x 10^14 Hz. So, if you spin a conventional solar panel at that frequency, it becomes bifacial.
Uponor make pex-a which is flexible. You can do a single run. But you might be right that cooling could cause a gradient and it would shatter. Maybe when i have money to burn ill try it though.The huge issue with this is the temperature differential on the solar panel. Having those water lines not leak is extremely difficult. If you can pull it off then so be it. I'd rather just paint a hose black and throw it on the ground and run water through it![]()
I had my ground deploy out with some layed out in front. It did increase the gain.Yet still ideal for playing/testing. Flat or lining a dish for more concentration.
I think the whole idea of reflectivity/albedo/diffuse/specular/concentrating, etc. is ripe for investigation. If only we could find someone who shares that interest, and has the capacity to perform experiments while having a communication platform to disseminate the real world results. A boy can dream...I had my ground deploy out with some layed out in front. It did increase the gain.
Might be a good idea for a video. To experiment with different kinds of reflective roof or ground surfaces like shingles of different colors, metal roofing, polished aluminum, elastomeric white roof coating, painted wooden surfaces, concrete, brick, ect
Things that are more applicable long term that dyi’s will be encountering or considering in their builds.
Hey @Will Prowse, rather than focusing on instant output performance, I would love to see a vertically mounted Bifacial and a mylar reflective surface in front of the panel. Does it improve performance (Yes!), does it improve the number of hours of production, Does it affect Volts/Amps capacity (it does not). Vertical bifacials and reflective mylar can significantly increase the efficiency of a system. BTW, I see this as the future of Agrivoltage system development.Before and after adding the mylar sheet:
Without reflective sheet:
With reflective sheet:
3.87% increase. 11am, so not peak irradiance.
