brackstone
- Mar 27, 2021
- 109
Hi all.
I have been talking to a few people on a Facebook group about the NDS SC300M solar controller. This controller is a MPPT device which charges the leisure and starter battery from solar panels
They have found when the sun goes down there is a current draw from the leisure battery with all the van switch off. If they pull the fuse from the NDS control unit the current draw goes to zero. So seems the leisure battery is reverse charging back into the starter battery (balancing both batteries).
If they operate the central locking on the van there is a small current draw from the leisure battery 2A for a few seconds which drops back of to zero.
So my question is are these solar controllers designed to balance the starter battery with leisure battery when solar has gone off(no sun).
If so when starting the engine will there not be current draw from the leisure battery.
Will it actually be feeding from the starter battery to van system and potentially draining the starter battery
