Hi
Just joined. First post ,please be gentle !
Hi.
Am in uk
I bought a 50w solar panel and a controller and an inverter a few months ago.
I also got a 12v 74AH Bosch battery second hand .
I wanted to run my small pond water pump (25w) by solar rather than mains.
Having watched some videos I put it all together and turned it on. Although not a very sunny time of year it worked straight away and last about 40 mins. I tried it again a couple of days later with similar results.
I then left it a while until we got longer periods of sun. Excited to see how long it may work for now , I recently tried it out again.
Now as soon as I plug the pond pump into the inverter and turn it on I get the error noise and have to turn it off again. I have done a fair bit of fiddling with the controller settings so they possibly are no longer the same as when it worked. However I have also tried just attaching the inverter to the battery and I get the same error noise.
I can connect a usb to either the panel, controller or inverter and each time it charges the device attached.
Although research suggested my equipment could cope with a pond pump ( and it was working) I wondered if somehow it was the pump so I tried attaching a coffee machine to the inverter and again I get the error noise and it turns the coffee machine back off.
I have a usb hub which has a 3 pin plug and when I plug that into the inverter it works and stays on.
At one point I wondered if it was the battery so I bought a cheap 12v one. It's made no difference .
I will try to list as many things below as possible but as a newbie may be missing some details.
25w pond pump
50 w solar panel
Solar controller
Bosh 12v battery 74AH
Lucas 12v battery 7AH
Inverter input Dc12v output ac 200-240v 50hz
The inverter has an on/off switch and two three pin socket holes and 4 usb sockets. It has a display which is currently showing DC input 12.3 and AC output 220. (Green led on )
Settings on controller
First screen shows panel icon and arrow going to battery (currently 12.6v)
Second screen showing battery icon at full 14.4v
Third screen shows 13.0v going to load
Next screen shows 10.7 v (atomatic turn off ?)
Next screen is on 24 hrs. ( I have tried reducing down to 1 or 2)
The last screen is battery type and showing 61 which I think is correct and was at that when working.
Both the pond pump and coffee machine work fine when plugged into mains electricity.
Any advice much appreciated
Alan
Hi.
Am in uk
25w pond pump
50 w solar panel
Solar controller
Alan
