Need 48v Low Amp Switches
HRTKD
Boondocker
Staff member
Moderator
Somewhere South of Denver
I need a couple of switches to enable/disable circuits going to a set of cooling fans. They're 48 volt but very low amps, less than 2 amps. Switches for batteries are huge overkill and wouldn't fit anyhow.
I already have the circuits fused so a breaker isn't appropriate. I'm not sure a fast blow breaker is even available.
The switches won't be used that often, only to take them down for maintenance. The fans are activated by other means.
I would do a simple test. Connect and disconnect using two copper wires and see what the arc potential is. I doubt it is much. A brushes motor will have a back EMF which reduces the differential voltage on the switch to a reasonable value. Brushless motors will have an internal capacitor which also keeps differential voltage small. You can always connect a couple uF oil capacitor across the switch if it is a major arc. I think any 120V AC switch will work fine. The test is just to satisfy your mind and let you sleep. This is not a critical circuit. Having switch stick on would not be a safety issue.
The fuse in the circuit does show a spark when inserting it. That's without the fans on. The PWM controller is between the PWM fans and the fuse.
Everything sparks a little. The concern is when it opens. Does it look like a hot spark that will sustain?
That's what I'm looking for! But dang, those are expensive. I expected it to cost more than simple 12 volt switches, but $13+ each on backorder at Mouser is more than I expected. I found a seller on Amazon for ~$11 each and put in an order for the 110-S-73 model. That's a single pole, 3a 250v/6a 125v, AC/DC switch with screw terminals.
As I've told other forum members, if you want to play in the 48 volt space, it's going to cost you a lot more money.
I really appreciate the link. It will work great for my use case.
As I said in the thread, I’ve never used those switches (but they are littelfuse/carling).
I would expect a big monster click clack sound out of them. :)
iirc, I did a parametric search for DC rated switches above 48V, and there were not that many to choose from for higher currents.
So of course, they would be expensive. Glad you found them on Amazon cheaper.
$15 for a 10-pack, much better!
The fans probably won't cause much arcing problem.
Just put an RC snubber across contacts to prevent burning.
Gotta figure out which leg you want to switch, unless you use DPST.
Normally switching hot would be the thing to do if negative side grounded.
But these could be connected to 48V all the time, because low side switch easier. I suppose you could still just switch high side, controlled low side doesn't matter.
Business Name: Changchunshihanghuimaoyryouxiangongsi
Well that just rolls off the tongue 😎
