Think of adding a 350A Circuit Breaker, but can't find one that doesn't make me nervous. I have three 12V 300AH 200A BMS batteries in busbar parallel, where it then goes off in 2 directions. The first with a 110A Class T off the + Bus Bar goes to the 12V 100A load accessories and 80A MPPT. The second direction with a 350A Class T off the + Bus Bar goes to a manual disconnect (Rated 350A continuous) and then to a 3000W inverter. Was wondering if I should put a circuit breaker that is 350A either 1 Pole or 2 pole, somewhere along this line before the inverter. Should I put a circuit breaker along here or not. Forgot to mention the batteries will have 250A MRBF on each one.
Looking for a product recommendation, If i should have one.
