YahwehisKing
- Mar 5, 2022
- 20
I've read and read and watched and watch I just need a sanity check to make sure I'm doing this right.
Setup planned is a 16s 48v 280ah batter pack (I bought the cells through DocanPower payed 147$ and they all got here in 5 days cells appear brand spanking new)
I purchased a 100amp Daly BMS everything else was backorder I'm still thinking of purchasing an overkill but not sure if it's truly necessary. I also purchased a 48v spf 3000tl lvm growatt. My question as with many is fuse size and cable size.
Should I use cable for my battery bus bars or regular bus bars, even the ones that comes with the batteries?
Should i use the windy nation 100amp ANL fuse after the battery between disconnect?? https://www.amazon.com/WindyNation-...fix=100+amp+t+class+fus,automotive,474&sr=1-9
If my 48/3000 62amps, which I won't be pulling anywhere near yet could i just use a 70amp tocas fuse?
Should I use 4ga which is rated at 70amp or go higher just for random surges if any?
Any help is much appreciated
