building new system. I have 10 Suntech STP285 - 20/Wfh solar panels wired 2s5p to end up with 62.8v, 45.4a, 1425w system.
Electrical Characteristics
STC STP285-20/Wfh
Maximum Power at STC (Pmax) 285 W
Optimum Operating Voltage (Vmp) 31.4 V
Optimum Operating Current (Imp) 9.08 A
Open Circuit Voltage (Voc) 38.3 V
Short Circuit Current (Isc) 9.48 A
Module Efficiency 17.2%
Operating Module Temperature -40 °C to +85 °C
Maximum System Voltage 1000 V DC (IEC)
Maximum Series Fuse Rating 20 A
Power Tolerance 0/+5 W
STC: lrradiance 1000 W/m2, module temperature 25 °C, AM=1.5;
Best in Class AAA solar simulator (IEC 60904-9) used, power measurement uncertainty is within +/- 3%
NOCT STP285-20/Wfh
Maximum Power at NOCT (Pmax) 210.2 W
Optimum Operating Voltage (Vmp) 28.9 V
Optimum Operating Current (Imp) 7.28 A
Open Circuit Voltage (Voc) 35.2 V
Short Circuit Current (Isc) 7.69 A
50 amp fuse
5KVA Solar Inverter 4000W 48V 230V Pure Sine Wave Hybrid Inverter Built-in 60A MPPT off-Grid Solar Controller Battery Charger
50 amp fuse
48v battery bank (I would like to use 4- 48v 99.999Ah 1000w 13S3P Lithium ion Battery Packs wired in parallel) these are elect bike packs so I would assume they need a new BMS.
50 amp fuse
shut off switch
480/230v eu to 120/240V us 1ph Transformer
50 amp fuse
MOES Dual Power Controller 50A 5500 Watt Automatic Transfer Switch for Off Grid Solar Wind System ATS DC 12V 24V 48V AC 110V 220V
with power from grid and solar array to electrical panel
This is the system I'm proposing, I actually have no idea if it's a feasible layout or not and figured asking here will get me started in the right direction
STC STP285-20/Wfh
NOCT STP285-20/Wfh
50 amp fuse
50 amp fuse
50 amp fuse
shut off switch
50 amp fuse
