I work on a heritage railway and we need to run a ~30v point machine on occasion. This takes around 7 amps for up to 10 seconds (maybe 10 amp starting) and is used maybe 8 times a day, a few days a year often with months in between uses.
Currently there is one panel that produces around 42v off load, a Renogy boost charger, 3x 110Ah lead acid batteries, and a 48-24v converter between the panel and Renogy as the panel generates too high a voltage in the sun for the Renogy which gives up. If the panel voltage drops too low the converter cannot maintain its 24v output, the Renogy will not accept the solar input, the batteries drain and then the Renogy refuses to even try to charge them.
So I want to start again and get it right.
We have used Victron products before and there is one, a Bluesolar MPPT 150/35 which has to be set to 36v by software and can apparently cope with flat(-ish) batteries (though I cannot now find that stated in their documentation). I also like the cellular reporting add-on they have. But I am sure there are other products.
Has anyone used or knows of a solar charger that will actually cope with batteries as they drop (maybe they all do, this is new to me). The last time we were there one battery had dropped to 6v, we have had them flatter and they will actually take a charge back at base but getting them back to base is a struggle. Any advice welcome!
