So I am looking into converting my AGM battery setup to Life4po server rack batteries.
I have one Growatt 5000 es and one Growatt 6000 es plus. 5000 runs my pool pump. 6000 runs my house load. They are independent of each other.
The common battery consists of two parallel strings of 150 ah AGM batteries, with battery equalizers. The DC bus feeds each inverter with equal length battery cables.
Is it possible to install a server rack life4po battery rack and share the DC bus connection to both inverters without using the CAN/485 comms connection.
I have been told by Growatt you cannot share the DC bus with dissimilar Growatt inverters when using lithium server rack batteries. They must communicate with the comms port on the server rack battery.
Any advice on this matter would be greatly appreciated.
I live in Costa Rica so moving to lithium is a very costly proposition for me.
Thank you. Ben
Thank you. Ben
