Need advise on canbus
I don't know the Growatt inverter nor its protocol. What helped me with debugging the DALY BMS protocol was actually a cheap logic analyzer I bought off ebay. Using this (https://www.ebay.de/itm/8-Kanal-24M...r-USB-Kabel-fur-ARM-Arduino-FPGA/293715300601) plus the Saleae software, I simply listened into the communication between the BMS and the PC software. That way, you can find out, if the Growatt CAN follows the CAN-bus protocol or something else.
I decided however, to stick with RS485 as the USB adapter appears as standard serial port while the CAN adapter has its peculiarities ...
Just make sure, if your device communicates using bytes or ascii!
Hello, is there any progress? My setup: Daly BMS Lifepo4 16S, Growatt SPH4600. would also like to use the Pylontech protocol for this purpose.
Does anyone know if there's been any work on adapting a generic BMS to report Pylontech formatted data for use with ME3000SP or similar?
Hi,
Im New to the forum but been working on this issue for a while.
finally had a breakthrough with this company
https://www.seplos.com/ who after some negotiation have sold me their
BMS https://www.seplos.com/sale-1332953...epo4-bms-monitoring-lithium-ion-battery-.html
Its taken 2 weeks to arrive but installed a few days ago and works as described ( On a test pack of 20AH lifepo4 cells. its communicating with my Me3000sp as a pylontech system ( Can choose in software between a range of off the shelf storage Batteries)
As the weather i the UK has warmed iv'e noticed the seplos BMS has instructed the Me3000sp to reduce charge to 10A and finishes off the charge as should to 80%.
The unit also comes with a satellite LCD display real handy.
Tony
Hi,
Tony
This is exactly what I have been looking for. I have sent you a message Tony.
Hi,
Tony
Thank you for the recommendation. I ordered from seplos.
Hi,
Tony
Hi, what all did you have to order from them? I am in same situation as you and I have already ordered batteries (lifepo4 280ah X 16) but I need a BMS which can talk to my ME3000SP without much fuss.
Do any Expert have Pylon protocol FW which is merged in Seplos BMS.pls share.
Thank
what are you looking for exactly, what are you trying to achieve ? RS485 and CANBUS Pylon protocol specs is widely available just google for it , seplos pylon implementation is also available on request. Not sure it is ok to share it here. however, as long as you stick to the the official pylon specs you're good with seplos also. most inverter use only a subpart of the whole protocol.
Hi Dear,
Iam seeking kind of this FW
in the Seplos PC sotware have a Droplist to choose hybrid inverter brands protocol. it aslo exist PYlon protocol on Droplist and i no need to upload.
I've purchase a new BMS Brand, it doesnt like Seplos. it require shall be upload BMS protocol from the upper computer. so i am seeking Pylon FW.
Thanks and support me!
Hi Dear,
Sorry, I'am not sure to understand your context, and what you are trying to do.Sorry
Are you tryng to use seplos PC software to upload a firmware in an other BMS brand ?
You can upload seplos firmware only on seplos bms, not in other bms brand.
If you have an other bms brand, you should ask your vendor if this bms support pylontech, and ask them how to enable it.
what is this bms brand ?
Hi Dear,
Hello Sir....Can you share me Battery Studio V4.3.310 ?
