Need electrician in Tampa Florida area for DIY solar permit.
I understand, but that’s how it works in my county.
Then you should challenge your AHJ to justify their position of illegally ceding authority to the utility.
It works that way on your county only because no has done that yet.
It is often not very hard to challenge this. Sometimes a simple letter to the AHJ asking them to justify their position in writing will put them in a position where they realize they can't and they will relent. If that doesn't work, then proceed with a permit application defying the utility mandate. If it gets rejected, again ask for the justification. Next step is a request on letterhead from a lawyer asking for the same thing. You don't have to do very much to start making the AHJ uncomfortable with its position when they realize they don't have a legal basis for it.
It is an obligation on the citizenry to keep government from exceeding its bounds.
Mike C.
Mike C.
Actually, I have the power company that allows homeowner to pull the permit, so that’s what I did.
"It is an obligation on the citizenry to keep government from exceeding its bounds."
I would, but once I get started I don't back down. So I will have to leave that to the younger generation.
I am in a similar situation now, except I have plans for 100% off grid, permits pulled, equipment installed and passed inspection.
Now, the town have decided I cannot get a CO because of no grid connection, even though my solar system is up and running 100%
They think FPL forbids them to issue a permit, and I am challenging that assumption.
I did a homeowner permit in Clearwater. It went pretty smooth. They made me change some conduit because I mismatch types and they made me put in a 2nd ground rod. I got the required engineering drawings from AltE when I bought my equipment. I paid a solar installer put my panels up.
My AHJ says I need a structural engineer to design my structural plans. The house has concrete tiles that are several tons on the roof and the solar system is basically nothing compared to that, so that defies common sense.
I went to Ironridge and used their design tools. The tool said, with XR-100 rails, I needed an anchor every 2 ft on every rafter. That's just bonkers, particularly since installing anchors on a tile roof is painful. That resulted in 116 tile anchors and a BOM adding up to $4,200. That's more than the panels cost. There must be something wrong with the tool.
I have a very simple array, 2 rows, nothing weird, no gaps, as simple as it comes. Where can I find an engineer who can make plans acceptable to the AHJ? Do they need a PE stamp, or just be engineered plans?
I looked at Greenlancer They offer a "permit plans set" service for $425. Fantastic, that would help me out. So I contact them and say I need plans. They send a quote back to me for $1325. Apparently, the plan set they make isn't done by engineers and it has to be stamped by outside PEs, one for electrical and one for structural, and those add up to an extra $900. Well, gee, that's not helpful if their plans set isn't good enough for my AHJ out of the box.
This solar thing is just one barrier after another to get anything done. It is very frustrating. If you talk to anybody in the "solar industry", all they see is money they can extract from you.
My project may end up dead just from the mental anguish. I'm depressed about it. Can't find plan service, can't find contractor, seemingly can't get anything done.
Mike C.
I thought the same thing when my friend was going through the permitting process. After talking with the structural engineer, I had to agree the rules are there for valid reasons. In this case Florida is a hurricane target. It is also very common for severe thunderstorms to roll through almost daily from April to October.
Solar panels are potential wind sails when installed on a roof. The entire concern from the structural engineering perspective was what type (and how many) attachment points to the structure were required to prevent a panel from becoming a flying death frisbee in a storm or hurricane. It had absolutely zero to do with the roofs ability to support the weight of the panels.
Mike C.
If you buy your panels and racking from a reputable company, they will help you get the stamped engineering plans for a reasonable price.
This is why I went to the Ironridge online configurator app and put in my parameters. My hope was if I put in the data, they can somehow spit out the structural plan set for low or no cost and I'd be set.
First issue is that the Ironridge system required 2 ft mount spacing (every rafter), which is totally ridiculous, so something is wrong with the configuration.
Second issue is that when you get to the end and hit the "Permit Pack" button, it takes you to Greenlancer. So I ended up back where I started.
Who else besides Ironridge makes racking systems with tile hooks? I can try others.
Mike C.
If you call the number I sent you, he will probably recommend that you buy your panels and racking from CE Greentech.
And they can help you get the stamped permit plan.
Just because you don't like the data, does not mean it is wrong.
Look at all the tornadoes this week, over a wide area of the middle of the country. No one wants thousands of panels raining down, hail is bad enough.
Having to anchor rails to every rafter is wrong. It just is. Maybe that's needed at the start or end of the array, but not every rafter in the middle.
The span tables Ironridge provide say XR100 should be good to 6 ft, and XR1000 to 10 ft for the wind rating needed in my area. Their tables don't even list 2 ft as an option.
No building code is written to survive a direct hit of a tornado, that is a completely unrealistic expectation.
Mike C.
I was going to login to Ironridge and check my install and put your area in to see if it made a difference and try to understand why it would want 2' rafter attachments.....but they got bought out and now it insists on making a new login, nope.
Ours is 160MPH in this part of Florida, equivalent to an EF3. Your local codes could be written with this in mind.
Do I want to test the theory in real life, not really.
XR100 is 6 ft span, XR1000 is 10 ft, per the chart for 160 MPH wind rating.
Not 2 ft span.
Something is messed up with the Ironridge online configurator.
Mike C.
Maybe, see if they will tell you what's up. It does seem wrong.
Actually mine are 48" span, 2 trusses worth.
Unless it’s off grid they claim FS 489.103(7)(A):
When installing, uninstalling, or replacing solar panels on one-family, two-family, or three-family residences, and the local permitting agency’s county or municipal government is participating in a “United States Department of Energy SunShot Initiative: Rooftop Solar Challenge” grant. However, an owner must utilize a licensed electrical contractor to effectuate the wiring of the solar panels, including any interconnection to the customer’s residential electrical wiring. The limitations of this exemption shall be expressly stated in the building permit approved and issued by the permitting agency for such project.
It works that way until somebody decides to stand up and say screw you. I’m not gonna do it that way. I’m gonna do it myself if you don’t like it take me to court.
I have installed my own system in Fla within FPL’s area. NO PROBLEMS. County law does not Trump state law. State law does not Trump federal law.
I designed the system, sent it out to get stamped, got permit, installed it, had the county inspector out to check ( now that was a joke since he had no idea what I did), passed it, asked me if I was going to enlarge the system since there was an empty space next the the lux 12k…. I looked at him and smiled…he said don’t bother pulling another permit; you know what you are doing (ok). So now I have two paralleled 12k’s pumping 24k. Diy
Think about what Solar does to the electric company and the other residents. Now you know why they really don’t want it
Power company rules cannot trump state statutes. If the state statute provides a means for the homeowner to be the contractor, then you can do so. The power company is not involved in the issuance of the permit to do the work, nor the AHJ inspection after the work is done, so you can proceed on that basis.
If an AHJ denies your otherwise valid permit application solely based on the utility rules, then they are violating the law.
Mike C.
Nothing new to see here "They" the county inspectors do that every day of the year.... all across America...
Mike C.
"If an AHJ denies your otherwise valid permit application solely based on the utility rules, then they are violating the law."
Nothing new to see here, that's how it seems to work all across the country. Public servants who have no reading comprehension skills and are drunk on their supposed authority.
I'm pretty sure none of our county inspectors have reading comprehension level above 3rd grade level, perhaps in Florida the AHJs suffer the same illiteracy problem that they have in Arizona?
No sabe nada mucho...
