Hello!
I'm looking for a buck converter of some kind that can take a ~12v input from a solar panel and is able to output it to ~3v. The hard part is finding a cheap one that can also charge a battery that is not LiPo, but a LiFePO4 battery (I have no clue if they need a charge controller, I'm sure they do though) I'd like to not go over 3.2v as I'm not sure how long it'll run at that voltage before it fries itself.
The LiFePO4 battery I have now is 3.2v
The buck converter I was using was a DROK DC Buck Module that I could tune down to ~3v which worked great... Until it didn't, it died overnight just having the battery and the weather station running on the output circuit. It won't power on if any load whatsoever is connected to the output (except for a voltmeter)
The Amperage needed is almost non-existent. When the Buck Module was working and connected the weather station only drawed about 0.02Amps for every transmission it sent out.
I'm not sure if I should get the same Buck converter (maybe it was faulty, or I did something wrong?) or a different one.
