chrishouse
I need help diagnosing and where to find a replacement BMS for the non-working RoyPow 48v160ah, model S51160, battery shown in the attached pics. I prefer a plug-n-play BMS, but realize that probably will not happen and I am comfortable and capable of DIY wiring if needed.
Batt has no power at the outside terminals.
Internally, measured before the contactor I am getting 53.25v.
When I press the power button the contactor clicks on, briefly has continuity through it and then clicks off and immediately releases giving no continuity.
I assume this means a bad BMS?
Any suggestions on a replacement? It is rated 160 amps Continuous, 315 amps for 30 seconds
