SolarHead
50% of people are below average. (Its a statistic)
If you remember, we have the following configuration (which works);
PV1A & PV1B will be 2 rows of 7 Canadian Solar panels and PV2A & PV2B will be 2 rows of 9 Mission Solar Panels. They can be arranged exactly as you mentioned, 2 rows of 16. Each row will have 7 Canadian Solar panels and 9 Mission Solar Panels.
PV1 has the following specs. Vmp (NMOT per datasheet) = 210V; Imp (NMOT per datasheet) = 15A (7.5A x 2); Voc =276V; Voc @0 deg. C. = 296V
PV2 has the following specs. Vmp (NMOT Estimated) =220V; Imp (NMOT Estimated) = 15A (7.5A x 2); Voc = 397V; Voc @0 deg. C. = 393V
My question is, what if I want to add more panels to my 32 panel array? with the Sol-Ark having two MPPT charge controllers, both are 500V max, I guess PV2 is pretty close to being maxed out, maybe its maxed out already? The more logical would be to add more panels to PV1, but those are the brand/model that was discontinued which lead me to buying the Mission Solar brand panels and ending up with 2 brands/models. I can buy more of what is used on PV2, but PV2 looks maxed out, I mean its at 393V and 500V max is what the Sol-Ark can handle on each MPPT.
