Hello all, I’m in need of some help!
I have an off grid skoolie application question. Here’s the pertinent system info:
-24v 100ah battery bank (expanding to 200ah eventually)
- Giandel 24v 3000/6000 inverter
- 60amp 120v AC panel
- 2x 20amp outlets
- 3x 15amp outlets
My issue: I bought the giandel because it had an AC terminal block. I was looking to wire directly from AC terminal block to an AC main panel. Based on the surge wattage (6000w) I calculated that I needed 4awg wire to supply the 60amp main, but upon pulling off the terminal block protection housing I see that it has tiny output terminals (picture attached). Does anyone know what these are rated for? I’m not sure how to wire my AC panel at this point.
- 2x 20amp outlets
- 3x 15amp outlets
