I need a bit of help in deciding which 100 watt flexible solar panel to purchase. 2 of these panels will be located on the roof of a teardrop trailer.
I'm not very knowledgable about specs of this sort and just basically need to gather some thoughts of others that will help me pick one over the other.
I've attached images of the basic specs from each panel (leaving "blank" the maker/distributor" of the panels to prevent bias.
Thanks for any thoughts. If necessary I can try and dig up additional info on the panels if that would help.
