Hi guys,
I ran into a strange issue and I'm new to solar so I would appreciate some suggestions/ideas.
My setup:
* Outback Flexmax 80 charge controller
* 4x 100AH LIFEPO4 batteries setup as a 48V system
* 4x 200W Panels hooked up in series* - Per panel stats: Pmax: 17.0V, current at Pmax: 11.76A
The current I'm getting from the solar array (hooked up in parallel) is only about 11 AMPs combined (measured by both Flexmax and manually via a multimeter). The wattage appears to be almost as advertised for the array at around 720W in full sun (60.2V "IN" reading in Flexmax), but the advertised amperage for the panels is not being achieved and I can't figure out why.
When I plug a single panel into the charger (or measure its current manually via multimeter) it's at around 7.2A in full sun per panel. But when I plug the entire array in (parallel) the current never exceeds more than 11A while the wattage is added up as expected at around 720W.
All wiring is done via standard high quality solar cables over a distance of about 10 feet (testing) from panels to charger.
Any ideas?
Thank you!
Luc
My setup:
Any ideas?
Thank you!
Luc
