DougL
It all depends on the BMS. Most all the 'standard' BMSs are well documented but since you're unaware of what the cells are doing it appears there's either no access to the BMS or you've chosen not to gain access. Personally, I would not own any 48V battery pack without some way of seeing what the BMS is doing and seeing all the cell voltages. A 'black box' of this size and power should have the ability to be monitored better.I appreciate the information. I guess the core issue or question is, is it normal for 2-48v batteries in parallel to discharge in the manner I described at the end of my previous post? And is it normal for 2 48 volt batteries to require a minimum power draw of, (as in my case 8 amps) for the 2 batteries to remain operational or remain awake ( through the BMS)? I am the first to admit I have a lot to learn and I am hoping that members of this forum will cut a less knowledgeable member a little slack. Thank you for for your advice!
And if they created a custom BMS who knows what 'features' they chose to implement.
