I'm a newbie but have spent last 6 weeks absorbing information here through a fire hose?. My primary goal was to have backup for critical loads during outages but also want to backfeed the grid (net metering). I estimate 5Kwh usage per day during outages. Here's where I stand now:
1. I have ordered 16 Lishen 270aH cells to build a 48V battery pack (13Kwh).
2. Solar panels should be delivered today (qty. 10 370 watt phono). 48.1 Voc, 9.3 Impp.
Now I need to pick out an inverter. Here's my list :
1. Outback skybox (5Kw) : Looks like it does everything I want. MPPT voltage range is 250-600V, so I would probably have to series all 10 panels ? Higher price than others, but UL listed and looks like good support.
2. Phocos Any-grid (5KW) : Not much information out there on this one, but about half price of skybox.
Others I looked at are Schneider, SMA, MPP.
Would appreciate your opinion on which one would fit my needs better or other issues I should look out for.
Thank you.
Thank you.
