Yes. A smartshunt is not a BMS and has its place alongside any other type of BMS.Did I miss something, OP is asking advise for the whole system, is that not what I was talking about, part of the system?
Sounds good. I've re-designed the system now to have 4 batteries of 3P 4S. (12 cells in each battery, 300Ah 12v). And the four batteries connected in Parallel for a total of 1,200Ah 12v (48 cells total). I'll need my Victron 500A Smart Shunt to give me an aggregate state of charge for all 4 batteries in my system together.But the victron is not a battery monitoring system at all.
It's primary value is an accurate aggregate state of charge of a system with multiple batteries. Something individual BMS units on each battery typically don't integrate together to accomplish.
You explicitly called referred to it as a battery monitoring system, or rather that it's insufficient and OP needs something better.I have never said that a smart shunt was a BMS, never.....I am referring to the Victron smart shunt the OP referred to in post #1. I see major problems with the proposed 16 cells in parallel but only pointed out how that many cells in parallel will cause balance problems between the cells in parallel but if you noticed i refrained from commenting on that further.
can you tell me exactly how a smartshunt is not a BMS and has its place alongside any other BMSYes. A smartshunt is not a BMS and has its place alongside any other type of BMS.
The product I've been talking about is a 500A Smart Shunt like I mentioned in the OP. I didn't know a battery monitor existed or what the difference is between the two or why you would need one and not the other which is why I'm confused. And don't worry, I never thought anyone said a BMS is a smart shunt, I know the difference.I have never said that a smart shunt was a BMS, never.....I am referring to the Victron smart shunt the OP referred to in post #1. I see major problems with the proposed 16 cells in parallel but only pointed out how that many cells in parallel will cause balance problems between the cells in parallel but if you noticed i refrained from commenting on that further.
A BMS monitors the cells within the battery.can you tell me exactly how a smartshunt is not a BMS and has its place alongside any other BMS
we were discussing what was causing his massively parallel flooded lead acid bank to be out of balance
I do not understand what a BMS has to do with a bank of 12 volt batteries in parallel.....
I have seen a BMS on a 48 volt bank of Rolls Surette 1100 a.h. 2 volt cells but never on a 12 volt battery
Exactly how do you do that?
Because you bunched the victron in with your comment about cell monitoring.Why do you keep saying that.....I never said that....what is your issue?
I am responding to @TommyHolly hereThe product I've been talking about is a 500A Smart Shunt like I mentioned in the OP. I didn't know a battery monitor existed or what the difference is between the two or why you would need one and not the other which is why I'm confused. And don't worry, I never thought anyone said a BMS is a smart shunt, I know the difference.
Here is a screenshot of my latest revision for the configuration which people helped me with in the other post:
What does it do that the smartshunt does not?What I said is in my opinion is that the Bogart Engineering TriMetric Battery Monitor is far better than the Victron Smart Shunt (a battery monitor)
