I really think you need to take some measurements yourself and do some math. I’m rather reluctant to make a recommendation for specifics because you’d doing somerging different than me. I don’t want you taking what I did and then one of your wires is a bit longer than mine, and then this starts a fire, which could happen with max inverter loads on a poor designed system.
People here will be more than happy to give you whether or not they think you did the math correct.
For specific wire size, there’s just too much that needs to be taken into account about. For example. I was told that 10 gauge wiring is fine for putting 6 panels in parallel. A couple things wrong with that is 10 gauge shouldn’t have more than 30 amps, which I would push up to 36 amps with that setup, and voltage loss is fairly significant.
I started With a DC online voltage loss calculator and aimed for between a 1% and 3% loss for each of my runs.
https://www.calculator.net/voltage-drop-calculator.html
I then aimed to have the max amperage I expected going through the wire to be so that it was rated for 60 C on the NEC ampacity charts
https://www.wireandcabletips.com/what-is-ampacity/.
I then had a good idea of the wires size I wanted, and then looked the wire manufactures specs to ensure this wire is rated for what I want to use. There’s a lot of different types of wires, and for example zip wire/speaker wire should not be used in most instances.
Finally for circuit breaker sizing for panels, I did short circuit amperage X 1.56, and then rounded up. I would recommed single POle 150 volt DC breakers or Dual Pole 300 volt breakers rated to the amperage yuo come up with. For my 2000 watt 12 volt inverter, although the wiring can handle it, I do not want to operate max power so instead of using the 350 and fuse my calculations came to, I toned it down to 200 amps. That 200 amp fuse is on the battery and is a ANL fuse rated for primary battery protection, not a cheaper ANL fuse for audio, and certainly not any of the higher amperage audio breakers having an easier installation that is much cheaper.
My opinion is you should have one charge controller for each panel, VICTRON 100 volt / XX amps which I’m sure not many would agree with. This is the same thing as setting up the system in parallel, but gets gives some redundancy if you ever lose a cvharge controller, keeps the wires a smaller gauge compared to paralleling, a few smaller rated charge controllers are not that much more compared to a single higher amperage charge controller, and makes it easier to add future upgrades for various reasons.
