Firetodd
Last year the forum assisted me in setting up a solar system for new 5th wheel. It works great and was able to power both my 5th wheel and my father-in-law's 5th wheel! So now I am building him a system, but we will not be adding solar panels... Here is the background, before I get to the questions:
I have a MPP LV6548 and a 48V 280ah battery with 3500 watts of solar. I have 6 panels on my camper, with 4 more on a patio next to the camper. But sometimes I am not at the lake and he would like to have power and use the 4 panels that are at the lake, when I am not there. He doesn't need much power.
So, I will be building him a system with a Growatt 3000 watt all-in-one and a 24V 230ah battery. This will run his camper. When I am there, it will be supplied by my system and store more solar power that I have not been able to capture as my batteries are full in the early afternoon each day. But when I am not there, he can hook up the mc4 cables from the solar panels on the patio and hook them up to the pigtail I will have connected to his Growatt unit.
The question I have is, the 4 panels (1100 watts) are in a series array so they output 133 volts, which is great for my MPPLV6548. But his Growatt unit lists a solar voltage input rating of 30-115 volts with 145 max. Is this too much voltage?
Also, if it is too high of voltage, could I put something to limit the voltage when it enters his camper, like a buck converter before the Growatt?
Or are my options: get him to add Three 200 watt panels to his roof, or take one panel off my patio array?
