Venezuela Solar
- Dec 6, 2019
- 146
Recently i bough a PIP 3048LV MK and a simpliphi 3.8kwh 48v (51v), simpliphi does not have a profile for the PIP and recommends using a 2 stage charger, so you know the PIPs are 3 stage algorithm, checking other inverters settings, like solark, Victron and outback, i get this voltages, 54.4 for absorption (in some cases it provides absorption time) and 54v float (as a place holder, float is disabled, but as a recommendation) so I'm thinking on setting the bulk to 54.4v, the float to 54 and cutoff voltage to 50.2v (80% D.O.D at c/2 by the manufacturer and recommended cutoff voltage)
It worries me to damage the batteries, by overcharging or not charging it completely, i also plan on using a watt meter for the battery so i can confirm how many watts go in after i discharge it to 50.2 at c/2
