Request advice on how to power a 1 Horse Power Single Phase (240V) submersible pump which takes around 6 Amps starting current.
I would like to power it through Solar Panels directly and also through a Battery system.
I have the following equipment with me and request your advice on what other equipment I need and how to connect the Solar panels to power this pump.
1. I have 4 Monocrystalline Solar PV panels of 24V, 250 Watt max power, 37.10 Volt max volt, 6.85 Amp., V.O.C 44.00V
2. I also have 4 Tubular Batteries which are 12V 150Ah each
Thank you for your help
