Gphoto125
I’m a newbie who needs help/advice….What size t fuse or other suggested type fuse and battery cable size will I need for my camper trailer that will have a single 12v 100ah lifepo4 battery? ( I thought I would use 8awg 0r 10awg cable ? )
The load on the battery at most will be @ 12 amps at any one time. I only am powering an exhaust fan @ 5 amps, led lights @.17 amps ea., and fridge panel draw which is @ 1.2 amps. A furnace fan is also 5 amps when running and needed.
I’ll be using either a single renogy 100w suitcase or possibly 2 of them in parallel through a Victron 75/15 charger and SmartShunt using 10awg cable. I also plan to use a 50a circuit breaker on the cable running to the Parallax 7345 45 amp ac to dc converter and a 20amp mega fuse coming from the charger/controller to the battery. Does this all sound reasonable ???
Thanks for any help and suggestions,
Gary P
Gary P
