Jerryonthego
- Jun 20, 2020
- 39
Hi All. Hoping to benefit from all th experience in this forum. I am new to solar and have been working on setting up solar in my shed. I have 8 435w panels connected (4P) to each LV2424 unit. The units are connected to a 14KWh battery bank. Each LV2424 unit works fine independently, however together (in parallel split phase) when I turn on the inverters and add a load, it trips my AC input breaker. One thing to note is that I plan to make this fully off grid, however I have both units connected to the same circuit for AC input. Not sure if that is the issue. The AC IN runs fine at 120v when the inverter is turned on… however once a load is added, my AC IN breaker (Gcfi outlet) is tripped. I’ll add some pictures shortly.
Please let me know what other info may be needed that I have left out. Apologies, new to this and have been looking for answers, but can’t seem to find a solution.
Battery info:
Lifepo4 24v
User settings (Will Prowse recommendations)
Thanks !!!
Battery info:
Lifepo4 24v
Thanks !!!
