WorldwideDave
Thanks in advance for reading!
Question #1 - discharge duration: I am trying to figure out how long I can run inverter/pump/heater on the pool before needing to stop it.
Question #2 - discharge time of day: I am also trying to figure out when is the best time to run my loads aka discharge battery.
On Tuesday end of day at 4 PM, I had no sun, and had brought my LiFePO4 battery down to 12.87 V which according to my victron smart shunt was 12% state of charge. I disconnected all loads from battery with kill switch, and went out to vote (live in the USA).
On Wednesday morning, I hooked up four (4) 200 W panels in 2 series, 2 parallel to a victron smartsolar 100V/20A solar charge controller. By 8:30 AM, I was at 13.39 volts on the battery, could see it was charging, and left overnight for business trip.
Today this morning (Thursday), I went and checked and battery was at 14.19V and 84% state of charge at 9:41 AM. By 10:30 (45 minutes alter) I was at 91% state of charge. 15 minutes later at 10:45 I checked, and battery was at 92% state of charge, but 13.93 V - less volts than 15 minutes ago.
Question #3 - why voltage goes lower when SOC higher: Not sure how or why voltage goes down when SOC goes up when zero loads connected.
I then went out again 30 minutes later, and SOC was 100%, but battery voltage was at 13.79 V (still less than 30 minutes or 45 minutes prior). Zero current, zero power, zero consumed Amp Hours on shunt.
Then I fired up my inverter, and started my pool pump and pool heater at 11:15. Battery reports 100% SOC, but voltage is 13.11, current is -20 amps, and time remaining indicates 7 hours 51 minutes (love this feature, but don't trust it so much yet). On solar charge controller, it shows max PV being delivered (290 for 12v), and battery at 13.11 (matching the shunt), and current at 20 A in bulk state.
I imagine that the state of bulk will change to Absorbtion very soon if not already.
Within 2 minutes of running pump, the state of charge reads 99%, voltage is 13.05, current is negative 21 amps, and time remaining is 9 hours 2 minutes (longer than prior).
Question #4 - How do others manage loads during the day? Do most people charge all day, then at night run loads off battery, or for my setup is it better to run the pool gear during the time the sun is out charging the panels?
My concern is that I hope to run the pool for longer than there is sun out to charge the panels, which requires more battery, bigger SCC, more panels, etc. I am getting those things, but for now, what is the longest I should run the inverter/pump/heater, and what time of day should I run them.
Thank you for reading!
