Need help with SPF 6000T DVM-MPV
carter
IM trying to get my panels amp up to match the SPF 6000T DVM-MPV . i have 12 rec panels 260watt and 10 powerlight panel 208watt .I have them in series going into a 4 string pv combiner box.. i have about 220 volts dc and only about 7 to 8 amp. the inverter runs about 48% load cap.with just 2000 watts load..The TECH at SS said i need more amps.when i wire the 4of panels parallel and the rest of the panels series it take my volts down to 72 volts amp up to 16 or so i need more volts .
Off Grid MPV Solar Inverter
SPF 6000T DVM-MPV
Maximum PV Charge Current
80A
DC Voltage
48V
Maximum PV Array Power
5000W
MPPT Operating Voltage(VDC)
60-245V
Max. PV Array Open Circuit Voltage
250VDC
Rec panel
RATED CURRENT: 8.50 A
OPEN CIRCUIT VOLTAGE: 37.8 V
SHORT CIRCUIT CURRENT: 9.01 A
MAX SYSTEM VOLTAGE 600 V
MAX SERIES FISE 15 A
FIRE RATING: CLASS C
Powerlight
PEAK POWER: 208 W
RATED VOLTAGE: 28.7 V
RATED CURRENT: 7.25 A
OPEN CIRCUIT VOLTAGE: 36.3 V
SHORT CIRCUIT CURRENT: 7.99 A
Quattrohead
Need to see how exactly you have your panels wired up, but it is not good to have different panels into 1 MPPT input.
The SPF6000 is lying to you, I have seen this odd behaviour. If you have a heavy load on one side of the split output, it seems to think that is the total load on both sides. I am still looking into this but as long as you know your load is OK, igmore the SPF reading for now.
carter
Thank you for your help ,as of now i have12 - 260 watt 2- string 6 panel wired in series,,, and the 208 watt all 10 in series all these goes into combiner box.
