Hagern.yacht
- Jan 24, 2020
- 21
the factory how install the system did the settings ? and the mechanic said its oke ????
on the photo's you see the generator just shut-down.... only the amps i did my self 200 amp what to many i set it on 100Ampthe water cames out of the Battery's
Victron mechanic have set the settings from the manuel ( from the battery's ) ???
I ask him normal it's max 28v charging ? for a 24v set ... he said it's ok ?????
All the settings are standerd installed in the victron by the fabric it self. I know it's to high voltage or to low.
All the 3 monteurs ( mechanic ) from victron say the same. So I don't know it anymore. ( I think the battery's are damaged !!! They don't hold the charging anymore 6 to 8 hours normal 3 days.)
So I think that I need new battery's ( send this battery's back to the factory and let dam handle it I have 1 year warranty).
That's why I want to go on litium battery's with a GOOD BMS/charger for that set. So I can't over/under charge .
Now is the question what do I need.
