SCClockDr
For relatively small $$ you could acquire 2 12V flooded deep cycle marine batteries & substitute them for your primary bank (no loads though)
Once installed run the ship off the generator & use the small generator to connect to the Victron. (A test bed if you will)
Draw the new batteries down to 75% SOC & start a charge. You need to observe & note what is happening (time, amps, & volts) say 5, 10, or 15 minute intervals.
If the Victron shuts down the charge secure the setup, disconnect the battery & share your log.
@ your discretion reduce your Victron voltages to 26.4 & 28.4 & see how that works & share that log.
