Hello everyone, I'm new to the form and am excited for my next project! After watching a lot of Youtube for inspiration I believe I have mostly finalized the design for the new solar system / battery upgrades I want for my house. I am hoping I can get input from people and any suggestions before I begin spending my money.
I currently live in a house that has solar with no battery and 100amp service. The house has a detached garage that I am planning on turning into an ADU/mancave. I am looking to use an IronRidge 3" ground mount system that I will raise up an additional 4' so that I can use it as a pergola / shade area for growing plants. The 18 solar panels will run in two strings to the inside of the ADU where I will have the FlexBoss and two EG4 Wall mount batteries. To connect the FlexBoss to the GridBoss I will have to trench 55' to my service panel. I plan on removing the solar inverter that handles the existing solar, putting a shutoff switch, and then running the two strings from it also through the 55' conduit so that it can plug into the FlexBoss other input port.
I have the entire backyard ADU online viewable cad design with what I want to accomplish here: https://app.sketchup.com/share/tc/n...yhSR28I0uKDbRzmxO7BfHTtPsC3JGQ2zBv&source=web
I also made a slideshow presentation of the plan I and order I want to work through the project. It includes pictures and cad drawings of my current setup and what I want to get done as well as components and cost estimates: https://docs.google.com/presentation/d/1U-2JkOQYl9A9mg1KzAt1hEU1s6uoCe1PQdR4pYEiDcM/edit#slide=id.p
The couple questions I have:
Will 2' conduit be big enough for the two 3 gauge cables from the FlexBoss to GridBoss as well as the four 10 gauge cables for the solar to the FlexBoss? I'm pretty sure it is, but will still be a bit of work pulling cables 55'.
Instead of running a 4 gauge grounding wire from the FlexBoss to the GridBoss can I install a Ground Rod next to the FlexBoss? If not, it will have to go in the conduit as well.
What is the process like to get a permit and PGE's approval for the changes I want to make? I feel confident in my knowledge and ability to install everything to code so that it will pass inspection. But how do I get that process started? Any estimates on how much it will cost?
Once I finally get started on my project I will be recording a time-lapse video of everything to document the project.
For those of you who read through this and looked at my plan thank you. Any feedback would be appreciated!
