LarryJForman
- Apr 7, 2021
- 57
I have some questions about using DIY LiFePO4 batteries for both starting my big block Olds 455 engine as well as running my 1970 Ultravan 22 ft Class A RV. I have been using two old (3-4 years old) Optima 12V AGM batteries that are now weak. I need to test them to see exactly how weak. I would like to migrate to DIY LiFePO4 12V batteries and hope to build one or possibly two 280 AH batteries. At this point I only have 2 100 Watt 12V panels powering a 40 Amp HQST MPPT solar charger and hope to add two more 100 watt panels in the near future. At this point I have not measured the big block engine starting current drain and need to verify that I don't over discharge any new Lithium batteries when starting the engine. I know the weak 12V AGM Optimas are still working OK at this point and able to start the engine reliabily. I wonder if I could just use initially one DIY 280 AH Lithium Iron Phosphate battery for both starting as well as house battery until I build a second battery for house use. I do know that I will need to add an alternator buffer so as to not over heat the alternator when on the road. I wonder if I could initially use maybe a 280 AH 12V DIY LiFePO4 for both engine starting and solar house battery and then build a smaller and lighter 100 AH DIY LiFePO4 battery for engine starting use for the big block engine? I do have a 2500 Watt Onan propane powered generator on board if I get into trouble and have a 70 Amp on board battery charger. I have a 2000 W pure sine wave inverter to power the AC system when on the road and boondocking. I also have a small roof A/C that I was thinking will likely not be able to be powered by a small 400 Watt solar system. Looking for some advice moving towards DIY LiFePO4 12 volt batteries. Since I just joined I will scour the posts and then be able to ask more intelligent questions. Many thanks for any suggestions. -- Larry Forman
